LUDIC ORPHEUS Power Cable Schuko Type E/F to IEC C15 24k Gold Plated OCC 6N Copper Shielded 1.5m
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent transmission quality. This cable has a diameter of Ø15mm and is equipped with multi-stranded conductors with a cross-section of 3.862mm². They are made of very high purity (99.9999%) OCC 6N copper and insulated with CPE sheaths.
Reference : 17370
195,00 €tax incl.
162,50 € tax excl.
Ludic Orpheus
Ludic Orpheus Câble Secteur Schuko Type E/F vers IEC C15 Cuivre OCC 6N Plaqué Or 24k Blindé 1.5m
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent transmission quality. This cable has a diameter of Ø15mm and is equipped with multi-stranded conductors with a cross-section of 3.862mm². They are made of very high purity (99.9999%) OCC 6N copper and insulated with CPE sheaths. A double shielding composed of an aluminum foil and a tinned copper braid allows to effectively repel interferences that could alter the signal. The cable is finally covered with a CPE sheath and a braided cotton sheath. The connectors are gold plated, maintaining an excellent level of conductivity while ensuring great durability.
Product typePower cable
Length1.5m
Connectors1* Schuko Type E/F
1* IEC C15
Conductors material6N OCC Copper
Conductors section3.862mm²
Conductors insulation materialCPE
ShieldingAluminum foil
Braided tinned copper
Cable diameterØ15mm
Connectors contacts plating24k Gold
External sleeve materialCPE
Covering sheath materialWoven cotton
ColorBlack and gray
Length (m)1.5
ShieldingYes
Section (mm²)3.86
ConnectorSchuko
ConnectorType F (CEE 7/3 - CEE 7/4)
ConnectorIEC C15
ConnectorType E (CEE 7/5 - CEE 7/6)
2 reviews
Rapport qualité prix exceptionnel
On en a réellement pour son argent d’abord pour la qualité de fabrication puis pour l’amélioration sonore. Tout reste équilibré en gagnant en silence. Grande douceur sans perdre en définition. Mention spéciale pour le grave complètement libéré mais sans lourdeur. Seul point négatif, câble très rigide. Ne pas hésiter à prendre une petite longueur supplémentaire. Ça aide. Comment d’habitude servie audiophonics au top
This review has been posted for LUDIC ORPHEUS Power Cable Schuko Type E/F to IEC C15 24k Gold Plated OCC 6N Copper Shielded 1.5m
Excellent rapport qualité prix
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent...
