LUDIC ORPHEUS Power Cable Schuko Type E/F to IEC C15 24k Gold Plated OCC 6N Copper Shielded 2m
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent transmission quality. This cable has a diameter of Ø15mm and is equipped with multi-stranded conductors with a cross-section of 3.862mm². They are made of very high purity (99.9999%) OCC 6N copper and insulated with CPE sheaths.
By buying this product you get 22 loyalty points
Reference : 17371
225,00 €tax incl.
187,50 € tax excl.
Ludic Orpheus
Ludic Orpheus Câble Secteur Schuko Type E/F vers IEC C15 Cuivre OCC 6N Plaqué Or 24k Blindé 1.5m
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent transmission quality. This cable has a diameter of Ø15mm and is equipped with multi-stranded conductors with a cross-section of 3.862mm². They are made of very high purity (99.9999%) OCC 6N copper and insulated with CPE sheaths. A double shielding composed of an aluminum foil and a tinned copper braid allows to effectively repel interferences that could alter the signal. The cable is finally covered with a CPE sheath and a braided cotton sheath. The connectors are gold plated, maintaining an excellent level of conductivity while ensuring great durability.
Product typePower cable
Length2m
Connectors1* Schuko Type E/F
1* IEC C15
Conductors material6N OCC Copper
Conductors section3.862mm²
Conductors insulation materialCPE
ShieldingAluminum foil
Braided tinned copper
Cable diameterØ15mm
Connectors contacts plating24k Gold
External sleeve materialCPE
Covering sheath materialWoven cotton
ColorBlack and gray
Length (m)2.0
ShieldingYes
Section (mm²)3.86
ConnectorType F (CEE 7/3 - CEE 7/4)
ConnectorIEC C15
ConnectorType E (CEE 7/5 - CEE 7/6)
ConnectorSchuko
Ludic unveils with the Orpheus a high-end Schuko Type E/F to IEC C15 power supply cable, using high quality materials to ensure excellent...
