OYAIDE TUNAMI GPXe RE Power Cable Schuko IEC C13 PC-OCC-A Copper Platinum Palladium Plated 1.8m
This high quality Oyaide Tunami GPXe RE power cable is equipped with a Schuko and an IEC C13 connectors with platinum and palladium plated contacts. The conductors of the cable are made of high purity PC-OCC-A copper with a cross section of 5.5mm², thus ensuring perfect electrical conductivity. The cable can withstand voltages up to 600V and currents up to 30A. This makes the Oyaide Tunami GPXe RE suitable for transmitting high power signals.
By buying this product you get 76 loyalty points
Reference : 17800
769,00 €tax incl.
640,83 € tax excl.
Shipping date: 22-04-2025.
OYAIDE TUNAMI GPXe RE Câble secteur PC-OCC-A IEC C13 Plaqué Platine Palladium 1.8m
It is also protected against noise and interference by a triple layer shielding. Its structure rejects not only internal and external noise, but also parasitic noise due to vibrations.
PC-OCC-A copper as conductor
PC-OCC-A copper is a very pure material, allowing any signal to pass through without hindrance or distortion. It is the combination of high technology and Japanese craftsmanship that gives it an extremely pure structure, ensuring optimum performance.
Strong shielding
This Tunami GPXe RE cable has a triple shielding. The first layer converts electromagnetic waves into thermal energy through an electromagnetic insulator. The second layer is a semi-conductive carbon layer that allows to discharge static electricity without affecting the main conductor. The last layer uses a copper foil that offers two advantages: it protects the conductor from external noise and it allows a grounding.
A highly efficient insulation
The insulation chosen here by Oyaide for its Tunami GPXe RE cable has the effect of eliminating the negative effects of vibrations thanks to a different degree of internal and external hardness.
High quality connectors (P/C-004)
The connectors (P/C-004) present on this 1.8m cable have been specially designed for it. Their beryllium copper contacts plated with platinum and a palladium make them very high quality connectors, ensuring both very good conductivity and resistance to oxidation. In addition, the outer shell "Aspirin snow white" made from polycarbonate allows to attenuate the vibrations thanks to its resistance and its hardness.
Product typePower cable
Length 1.8m
Outer diameterØ11mm
Cable conductors materialPC-OCC-A copper
Connectors P/C-004 special edtion (Aspirin Snow White)
Connectors contacts materialBeryllium copper
Connectors contacts platingPlatinum
Palladium
Rated voltage/current250V / 10A CE
ColorCable: black
Connectors: white
Quantity1* Oyaide Tunami GPXe RE cable
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorIEC C13
ConnectorSchuko
This high quality Oyaide Tunami GPXe RE power cable is equipped with a Schuko and an IEC C13 connectors with platinum and palladium plated...
