OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 102 SSC / OFC Copper Gold 24k Palladium Plated 1.8m
This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts. The conductors of the cable are made of high purity 102 SSC and OFC copper with a cross section of 5.5mm², ensuring perfect electrical conductivity. The cable can withstand voltages up to 600V and currents up to 30A. This makes the Oyaide Tunami GPXe suitable for transmitting high power signals.
Reference : 12615
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 22-04-2025.
OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 PC-OCC-A Copper Gold 24k Palladium Plated 1.8m
It is also protected against noise and interference by a triple layer shielding. Its structure rejects not only internal and external noise, but also parasitic noise due to vibrations.
102 SSC / OFC copper as conductor
Oyaide Tunami GPXe V2 features 102 SSC copper conductors for hot and cold spots, and OFC copper for the ground conductor. This ensures excellent electrical conductivity for highly efficient signal delivery.
Strong shielding
This Tunami GPXe cable has a triple shielding. The first layer converts electromagnetic waves into thermal energy through an electromagnetic insulator. The second layer is a semi-conductive carbon layer that allows to discharge static electricity without affecting the main conductor. The last layer uses a copper foil that offers two advantages: it protects the conductor from external noise and it allows a grounding.
A highly efficient insulation
The insulation chosen here by Oyaide for its Tunami GPXe cable has the effect of eliminating the negative effects of vibrations thanks to a different degree of internal and external hardness.
OYAIDE TUNAMI GPXe Câble secteur PC-OCC-A IEC C13 Plaqué Or 24k Palladium 1.8m
High quality connectors (P-046e/C-046e)
The connectors (P-046e and C-046e) present on this 1.8m cable have been specially designed for this cable. Their 24k gold and palladium plated contacts make them high quality connectors, ensuring both a very good conductivity and resistance to oxidation.
Product typePower cable
Length 1.8m
Outer diameterØ11mm
Cable conductors materialPC-OCC-A copper
ConnectorsP-046e
C-046e
Connectors contacts plating24k gold
Palladium
Rated voltage/current125V / 15A CE
ColorCable: Black
Connectors: Red
Quantity1* Oyaide Tunami GPXe cable
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorSchuko
ConnectorIEC C15
Parfait
Branché sur une barrette actinote grande musicalité très bons timbres ça ouvre
Tout cela sans être fatiguant au contraire on en redemande !
Bref a ne pas essayer sinon ...
This review has been posted for OYAIDE TUNAMI GPXe V2 Power Cable Schuko IEC C15 102 SSC / OFC Copper Gold 24k Palladium Plated 1.8m
This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts....
