OYAIDE VONDITA-X Power Cable 1.8m
Oyaide's Vontida-X is a high-quality power cable, consisting of 3 twisted 102SSC copper conductors, each with a cross-section of 4mm². These are insulated with a polyolefin sheath, and then shielded with copper foil. The whole is protected by a polyolefin sheath and covered with a PVC outer sheath.
By buying this product you get 189 loyalty points
Reference : 20481
1 890,00 €tax incl.
1 575,00 € tax excl.
Oyaide Vondita-X Power Cable US NEMA 5-15P to IEC C13 Copper 3x4mm² 1.8m
OYAIDE VONDITA-X : Front view
Oyaide's Vontida-X
OYAIDE VONDITA-X : Cable composition
The connectors contacts are made of beryllium copper, with different plating on each end. The mains connector features platinum and palladium plating, providing protection against oxidation while guaranteeing high mechanical resistance. The IEC13 connector, on the other hand, features gold plating to offer rock-solid protection against oxidation, while maintaining excellent conductivity levels.
Technical specifications
Product typePower cable
Length1.8m
Connectors1x NEMA 5-15P
1x IEC C13
Conductors102SSC Copper
Cross-section3x 4mm²
InsulationPolyolefin
ShieldingCopper foil
External sheathPolyolefin + PVC
Outer diameterØ13mm
Connector materialBeryllium copper
Connector platingNEMA 5-15P : Platinum and Palladium
IEC C13 : 24K Gold
ColorRed
PackageSold individually
Length (m)1.8
ShieldingYes
Section (mm²)4.00
ConnectorNEMA 5-15
ConnectorIEC C13
Conductors material (Cable)Beryllium Copper
OYAIDE VONDITA-X Power Cable US NEMA 5-15P to IEC C13 Copper 3x4mm² 1.8m
Oyaide's Vontida-X is a high-quality power cable, consisting of 3 twisted 102SSC copper conductors, each with a cross-section of...
