PANGEA AC-14SE MKII Power Cable IEC C7 Triple Shielding OCC / Cardas 3x2mm² 1.5m
Based on a mix of solid strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source components that do not require the same current power as receivers and amplifiers.
Reference : 18644
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 25-04-2025.
Pangea AC-14SE MKII Power Cable IEC C7 Triple Shielding OCC / Cardas 3x2mm² 1.5m
Based on a mix of solid strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is specially designed for source components that do not require the same current power as receivers and amplifiers. It provides more current, while offering multiple shielding and other features that facilitate extremely clean and noise-free powering of your devices.
It will improve the performance of preamplifiers, CD players, DVD players, CEDs and other line-level components. The AC-14SE MKII consists of a PC-OCC single-stranded conductor surrounded by 6 independently insulated Litz wires, ensuring maximum purity of the delivered current. The independent insulation of each of the conductors ensures a level of power quality unmatched in this price range.
The AC-14SE MKII contacts are 24k gold plated for superior conductivity.
Pangea AC-14SE MKII power cable components Pangea AC-14SE MKII power cable components
Product typePower cable
Connectors1x IEC C7
1x Schuko
Cable conductors6 OFC Copper strands, surrounded by 6 Litz wires
ShieldingSilver plated Copper foil
Noise shielding spiral (EMI, RFI)
Connectors contacts24k Gold plated PC-OCC Copper
Cable diameterØ12mm
Length1.5m
Length (m)1.5
ShieldingYes
Section (mm²)2.00
ConnectorSchuko
ConnectorIEC C7
Conductors material (Cable)Cardas Copper
je recommande
Acheté pour remplacer le câble alimentation de mon streamer/preampli/dac Yamaha WXC-50. Ce streamer se trouve très près de la livebox que soupçonne introduire des parasites dans le Yamaha via le câble secteur. Avec le nouveau câble je cherche à éliminer ces courants parasites induits par le rayonnemet électromagnétique de la box. Le câble est assez lourd et il remplie bien son rôle. Attention quand même au poids par rapport à l'embranchement dans le dispositif: il peut se déconnecter de façon inopinée. Est-ce que le câble rempli son rôle ? Je trouve que l'image sonore a un bien meilleur rendue, plus large et les instruments mieux localisés.
This review has been posted for PANGEA AC-14SE MKII Power Cable IEC C7 Triple Shielding OCC / Cardas 3x2mm² 1.5m
Based on a mix of solid strands and Litz wires, this cable is especially designed for your audio sources. The Pangea AC-14SE MKII cable is...
