PANGEA AC-14SE Triple mains cable Shield OCC 3x2mm² 1.5m
4.9 / 5
Reference : 6060
75,00 €tax incl.
62,50 € tax excl.
PANGEA AC-14 SE Shielded cable OCC 14-AWG 1.5m
Foodextremely clean and noiselessfor the source components.
Based on a mix of solid strands and litz wires, this cable is specifically designed for your audio source.
The Pangea cable AC-14SE isspecially designed for source components,which do not require the same current power that receptorsowersand amps.TheAC-14 SEprovides more current, while offeringmultipleshieldsand other features which facilitatesupplyextremely clean and noiselessof your devices.
Pangeahas designed the AC-14SEspecifically for supplysource components "Audiophiles".It will improve the performance ofpreamps , CD players, DVD players, CED,and otherscomponentsof line level.
TheAC-14 SEis composed of a conductors single-stranded PCOCCsurrounded by 6 independently insulated litz wires guarantorissuingpurity maximum current delivered .
The independent insulation of each conductor ensures an unmatched level of power quality in this price range.
The contacts of L 'AC-14SE aregold plated 24k to provide a conductivity higher.
Specifications:
  • Designed for source components
  • Better transient response, lower noise floor
  • A combination of solid and Litz conductors
  • One large-gauge solid PCOCC copper center conductor
  • Six medium-gauge solid OFC copper conductors surrounded by six Litz conductors
  • Silver-plated copper braided shield
  • Designed specifically for wide-band delivery of power to line-level AV components
  • Specifically designed to enhance the performance of preamps, CD players, DVD players, DACs, and other line-level components
  • Counter-spiraled conductors for superior noise rejection
  • Superior flexibility for easier installation
  • Lightweight design does not impede the effectiveness of isolation devices
  • 24k gold-plated contacts for superior electrical contact
  • Special two-shot molded connector
https://www.audiophonics.fr/images2/6060/6069_PANGEAAC14SE_1.jpg
https://www.audiophonics.fr/images2/6060/6069_PANGEAAC14SE_3.jpg
https://www.audiophonics.fr/images2/6060/6069_PANGEAAC14SE_2.jpg
https://www.audiophonics.fr/images2/6060/6069_PANGEAAC14SE_4.jpg
Length (m)1.5
10 reviews
Remarquable.
Câble secteur tout à fait remarquable par les résultats musicaux qu'il permet d'obtenir, sans dénaturer l'équilibre sonore le moins du monde; les voix en particulier sont magnifiques, l'image profonde, les timbres élégants, le grave tendu mais sans excès, tout celàpour un tarif très doux. Il fait bondir le petit Qinpu A6800, déjà très méritant jusqu'à un niveau musical inespéré.
Attendre quelques jours sous tension avant tout jugement.
Conseillé !
This review has been posted for PANGEA AC-14SE Triple mains cable Shield OCC 3x2mm² 1.5m
Excellent
Câble de belle fabrication, assez souple malgré son large diamètre. Rendu superbe, matière, détails, texture sont au rendez vous. Bande Passante très étendue, basses bien tendues. Utilisé sur un Oppo HA 1, un régal. Un vrai bon câble à un prix d'un milieu de gamme.
Les mystères du secteur!!
Ce câble remplace sur le lecteur CD, mon YARBO 1100 avec prises FURURTECH qui va sur l'ampli à la place du YARBO 8000... Résultat: une amélioration spectaculaire!! Aigus magnifiques, basses mieux maitrisées, son plus clair et plus percutant...Quelle musicalité!!
A recommander chaudement.
utilise avec un adapateur pangea iec c14 sur un conditionneur réseau isotek aquarius, j'ai note plus d'ouverture, de clarté et de dynamique. rapport q/p exceptionnel comme les autres câbles de la m
arque.
merci audiophonics.
bonjour
j'ai commander le PANGEA AC-14 SE pour tester etan donner que ce câble d'alim a une construction aux fils de litz + OCC + OFC
et je peux vous dires quille ma bluffer c'est performances musicaux et Sonic sont ce que j'ai écouter de meilleures a ce jour
et proutent je dispose d'un système purement audiophile de très très au niveaux
purement a tubes audio note + klipsch la scala lecteur CD pur tube + filtrage protecteur secteur et câblages d’exceptions etc.. bref un systèmes vintages comparables a des systèmes modernes a 70 000 euro facile
et bien je peux dire que ce câble d'alim pourtant peux chère a suplenter tous les câbles d'alim que j'ai déjà tester valent très chère
je le recommande donc sens aucune retenus c'est un câble exceptionnelle a tous les niveaux IL EST BLUFENTS
cordialement Christophe
