PANGEA AC-9SE MKII Power Cable Triple Shielded OFC Cardas Copper 3x10.5mm² 1m
The power supply cable Pangea Audio AC-9SE MKII has been specifically designed to provide the power required for high power mono or stereo amplifiers. It is also ideal for amplified subwoofers and is an excellent choice for use with demanding high voltage line conditioners.
Reference : 10502
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 22-04-2025.
Pangea AC-9SE MKII
Pangea AC-9SE MKII Câble Secteur Triple Blindage Cuivre OFC Cardas 3x10.5mm² 3m
Its combination of superior quality materials, advanced design and shielding improve the performance of connected components.
The new AC-9SE MKII is equipped with a gilded conductor pair Cuivre OFC and Cuivre Cardas Grade One, specially developed by George Cardas for his own cables. This sector cable also has triple OFC Copper braided Silver plated shielding.
Due to their high current requirements, power amplifiers must have larger conductor sizes than standard power supply cables generally offer. The Pangea AC-9SE MKII is the perfect answer to this constraint.
Product typePower cable
Connectors1x Schuko
1x IEC C13
Length1m
Cable conductorsOFC Copper
Cardas Copper
Section3x10.55mm² (7AWG)
Triple shieldingBraided Silver plated OFC Copper
Connectors contacts24k Gold plated OFC Copper
Cable diameterØ23mm
Weight1660g
Cable colorBlack, gray and blue
Length (m)
  • 1.0
Shielding
  • Yes
Section (mm²)
  • 10.50
Connector
  • IEC C13
  • Schuko
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
3 reviews
Nette amélioration du son
Bonjour, j'ai acheté 2 câbles Pangea secteur, car ils étaient en promo et que je souhaitais depuis longtemps avoir des câbles secteur haut de gamme. Je n'ai pas été déçu et j'ai même, pour l'instant reporté le renouvellement de mon matériel au niveau Ampli, car le son est amélioré par ces câbles en précision, clarté et détourage. J'en achèterais deux autres car mon projet est : deux amplis mono de puissance et un préampli certainement le monocéros de chez Audiophonics. En attendant, j'ai un son super. Attention, la section de ces câbles est énorme, on est surpris au déballage et ravi par le son. Autre aspect, la prise femelle tient très bien sur les appareils, pas de jeu, donc une bonne connexion, donc un plus pour le son. Je recommande et à mon avis ce n'est pas forcément la peine d'acheter plus cher...
This review has been posted for PANGEA AC-9SE MKII Power Cable Triple Shielded OFC Cardas Copper 3x10.5mm² 1m
Pangea
Après réception de mon câble PANGEA AC-9SE MKII, j'ai pu le mettre en place tout de suite sur mon Ampli Audio Analogue , j'ai été surpris par autant de détail ainsi que l'espace autour des enceintes . Je pense avoir eu une nette amélioration qu'aucun câble de modulation sur mon système jusqu'à ce jour.
Il n'est même pas encore rodé ?
Une belle trouvaille à ce prix bravo Audiophonic.
Super Cable!
I already had several Pangea cables. I bought this for my Cambridge Audio CXA60 amplifier. It works wonderfully. The sound space opened. The beautiful clear high tones came. Hear all the instruments in place. The whole system has been renewed! I would like to thank Audiophonics for delivering to Hungary so quickly and correctly.
The power supply cable Pangea Audio AC-9SE MKII has been specifically designed to provide the power required for high power mono or stereo...
