EMIKON HPF-1540 Power Filter
The Emikon HPF-1540 is a sector filter specially designed to eliminate interference induced by industrial and domestic equipment on the CENELEC-A EN50065 frequency band used in PLC systems (Prime, G3, Counters, Smart meters, etc.). This filter is therefore ideal for attenuating the interference generated by a Linky counter.
Reference : 19183
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 24-04-2025.
Emikon HPF-1540 Power filter 40A CENELEC-A EN50065 (40dB attenuation on tape 10kHz - 35kHz)
Emikon HPF-1540 Filtre secteur 40A 40dB CENELEC-A EN50065 Linky
The Emikon HPF-1540 is a power line filter specially designed to eliminate interference induced by industrial and domestic equipment on the CENELEC-A EN50065 frequency band used in PLC systems (Prime, G3, Counters, Smart meters, etc.). This filter is therefore ideal for attenuating the interference generated by a Linky counter and also protects your electrical devices (PC, TV...) connected to the home network.
To reduce these interferences, the PLC filter applies an attenuation of more than 40dB on the CENELEC-A EN50065 frequency bands used by new generation electricity meters. The maximum supported current is 40A, suitable for most domestic installations.
The HPF-1540 is designed to integrate directly into your electrical panel, at the top of the installation, just after the meter, this filter is mounted in a standard housing using 4 units. It is equipped with a hook for mounting on standard DIN rail. The cables are firmly held in place by fixing them to pairs of screws. The slots can support a variety of cabling from 6 to 16mm² of cross section.
This equipment requires a modification of your electrical panel, it must be installed by a professional in accordance with the standards in force.
Localized filtering
Emikon PLC filters do not restrict the operation of communicating meters in any way. All the functions of the device continue to operate normally and this filter cannot be used to prevent the meters from collecting information about the details of your power consumption.
A PLC filter simply attenuates at a local scale (your home electrical network) the frequencies that meters use to communicate with each other. This process does not affect the meter, which only uses these frequency bands to communicate outside your network.
Product typePower filter
Single-phase power supply1x 110 / 275 VAC
Nominal frequency50 - 60Hz
Nominal current40A
Attenuation> 40dB 10kHz à 35kHz
Protection classIP51
Test voltageP → P/N 2250VDC P/N → E 3000VDC
ReliabilityMTBF 220.000h @ 50°C
Min/Max operating temperature-25°C / +100°C
Min/Max cable section6mm² - 16mm²
Dimensions72 x 103 x 78mm
Weight1.3kg
EMIKON HPF-1540 Power Filter 40A 40dB CENELEC-A EN50065
The Emikon HPF-1540 is a sector filter specially designed to eliminate interference induced by industrial and domestic equipment on the CENELEC-A...
