FURUTECH FLOW-C15 EMI AC-1501G Main Filter IEC C15
The Furutech Flow-C15 mains filter protects the AC power signal of your Hi-Fi equipment. It protects your system from distortion, voltage peaks and troughs, power supply noise and high-frequency digital noise from processors and digital interconnects.
By buying this product you get 33 loyalty points
Reference : 20196
330,00 €tax incl.
275,00 € tax excl.
Furutech Flow-C15 EMI AC-1501G  Main Filter Gold Plated α (Alpha) Copper IEC C15
FURUTECH Flow-C15 picture
The Furutech Flow-C15 mains filter protects the AC power signal of your Hi-Fi equipment. It protects your system from distortion, voltage peaks and troughs, power supply noise and high-frequency digital noise from processors and digital interconnects. To achieve this, the Flow-C15 is based on the use of an AC-1501 (G) EMI filter connector and copper alloy conductors with α (Alpha) treatment and 24k gold plating.
As an added bonus, its slim form factor means it can also be used on TVs or low-profile devices.
In terms of performance, the Flow-C15's parallel circuit with coil and in-line capacitor reduces noise at 100 KHz by 8dB, at 500 KHz by 14dB and at 10MHz by over 30dB.
Product typeIEC C15 mains filter
ConnectorAC-1501 (G) with EMI filter
Connectors contactsCopper α (Alpha) 24k gold-plated
Cable conductors37x Copper strands μ-OFC α (Alpha) silver plated (0.25mm x2)
37x Copper strands μ-OFC α (Alpha) (0.25mm x1)
InsulationPE
ShieldingCopper braid α (Alpha) (Ø0.12mm)
SheathPVC
Noise reduction100kHz (8dB)
500kHz (14dB)
10MHz (30dB)
Current/VoltageAC 125V 15A
AC 250V 10A 50/60Hz
Package1x Furutech Flow-C15
FURUTECH FLOW-C15 EMI AC-1501G Main Filter IEC C15 Gold Plated Alpha Treatment Copper
The Furutech Flow-C15 mains filter protects the AC power signal of your Hi-Fi equipment. It protects your system from distortion, voltage peaks and...
