By buying this product you get 74 loyalty points
EMI AC-1501 (R) Main Filter Gold Plated
The EMI Flux-50 NCF (G) mains filter features the latest revolutionary technology developed by Furutech. Depending on the quality of the AC current that feeds your audio system, it can be enhanced or greatly reduced. The audio you hear comes primarily from this AC current, and severe thunderstorms that can occur are very detrimental to the performance of your components.
The Flux-50 NCF (G) is a luxurious and ultra-sophisticated mains filter, which eliminates many problems caused by faulty upstream power lines and current. It protects against distortion caused by background noise as well as voltage spikes and drops. High-frequency power supply noise as well as digital noise from processors and other digital interconnects make this high-end mains filter a must for maximum performance.
Integrated in the latest Furutech products, the NCF (Nano Crystal² Formula) technology consists of a special crystalline material with two active properties. First, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) with wavelengths ranging from 50µM to 5mm. Furutech then combines this remarkable material with nanometric ceramic particles and carbon powder for their piezo effect (damping property). The resulting NCF formula is the ultimate electrical and mechanical damping material.
Moreover, in this version (G) of the Flux-50 NCF, the contacts of the IEC connector as well as the EMI filter are gold plated in order to maintain an excellent conductivity while ensuring an excellent resistance to oxidation.
The results and readings show very clearly that the Flux-50 NCF reduces noise, oscillation and resonance in the cable by 10 times. The result is a natural and accurate sound and a totally silent sound floor.
Product type | Main filter |
Filter | AC-1501 (G) |
Conductors | OCC Copper, Alpha (α) treatment |
Contacts / filter plating | Gold |
Filter material | Non-magnetic copper alloy |
Filter treatment | Alpha (α) |
Noise reduction | 1MHz (10dB) 10MHz (+30dB) |
Shielding | Alpha (α) treatment |
Insulation | PE |
External sheath | PVC |
Covering sheath | Braided nylon |
Voltage / Current | 115-250VAC 15A 50-60Hz |
Cable diameter | Ø18.8mm |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
