IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC
The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the presence of a ground loop and corrects it.
Reference : 15215
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-04-2025.
iFi Audio GND Defender Filtre d'Alimentation Secteur Boucle de Masse 90-240V AC
The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the presence of a ground loop and corrects it. The crossover plugs directly and easily into the IEC connector of your device. It also incorporates EMI shielding to limit external interference.
Product typeMain power supply filter for ground loop
Voltage rating90-240V AC
Continuous current10A (1100W - 2400W)
Surge overload rating220A
Dimensions68 x 37 x 32mm
Weight61g
ColorWhite
Rated current (A)10.0
3 reviews
Exellent
Used it directly on my PC's power supply, i have Topping E30/L30 stack and my speakers were noisy, now i don't have the problem anymore. You only need 1 of those if you have a ground loop.
This review has been posted for IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC
Great
Works great, mains noise has been eliminated. Sound quality was not affected. I am very satisfied.
mauvaise conception
Si votre interrupteur marche est situé au dessus de votre prise IEC dans bien des cas lorsque vous brancherez le gnd defender ou DC blocker vous ne pourrez pas l enclencher à fond car il viendra heurter l interrupteur de marche arrêt.
Prenez garde !
The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender...
