SCHAFFNER FN9222 IEC Anti-Parasites / EMI 230V 1A
Reference : 5443
9,90 €tax incl.
8,25 € tax excl.
SCHAFFNER FN9222 IEC Anti-Parasites / EMI 230V Sector Filter
The reference in the field of high-performance mains filter: the model FN9222 of the Swiss manufacturer SCHAFFNER and designed to filter the disturbances when the capacitors prove insufficient.
Very effective against electromagnetic disturbances (EMI) propagated by radiation or conduction.
Product in accordance with IEC 950, approved UL, CSA, TUV, SEMKO, NEMKO and FIMKO, which meets the requirements of Class II surge (IEC664).
Non-medical version for better filtering
(Cy capacitors in addition to the FN 9222)
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_1.jpg
Specifications:
  • Operating Voltage: 250V Max 50 / 60Hz
  • Leakage Current: 373μA
  • Operating Frequency: Up to 400Hz
  • Capacity Cx: 0.1μF x2
  • Capacity Cy: 2.2nF x2
  • Self: 12.0 mH x 2
  • Resistance: 1MΩ
  • Operating Temperature Range: -25 ° C to + 85 ° C
  • Certifications: UL, CSA, TÜV, SEMKO, NEMKO & FIMKO
  • Weight: 40g
  • Recessed dimensions: 28x20.5mm
  • Faston
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_3.jpg
AT :48mm
B:22.5mm
C:40mm
D:38.4mm
F:5.5mm
H:3.3mm
J:13.3mm
S:90 °
https://www.audiophonics.fr/images2/2875_SCHAFFNER-FN9222B_2.jpg
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Contacts Plating (Connector)N/A
Rated current (A)1.0
2 reviews
Valeur sûre et efficace !
Utilisé pour ajouter une prise IEC à un préampli Audio Research en remplacement du cable d'origine.
Résultat : plus de parasites car j'avais un fond de radio en poussant le volume. Plus de silence et le son s'est légérement adouci. Le gain a été trés appréciable surtout audible au niveau de l'entrée phono.
A recommander pour tout appareil audio à faible consommation, terminé les parasites !
 (3)
This review has been posted for SCHAFFNER FN9222 IEC Anti-Parasites / EMI 230V 1A
J'ai installé ce filtre sur ma vieille platine Marantz CD53 qui était équipée d'un câble type grille-pain. Combinée à un Kit câble DIY Audiophonics Secteur PCG3 Blindé 3x2.5mm² 2.00m, le résultat est sans appel : musicalité, naturel et gain de volume. Facile à mettre en œuvre, je le recommande chaudement.
 (3)
