Connector
Max cable diameter (mm)
Rated current (A)
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Mounting type
patrick a.
Relié en optique au drive et en coaxial au steamer,
ce joli petit dac offre un son chaud et musical, sans aucune agressivité.
Francois g.
Un très bon cable
Cable Utilisé pour relier un IPad avec Quobuz à mon dac : Cette solution simpliste fonctionne tres qualitativement et me...
Serge l.
Quel ampli !
Utilsation hifi, home cinema, mastering !
Ultra precis sans etre froid, maitrise absolue de mes enceintes dont le HP de grave...
Power Plugs & Sockets
Power Plugs & SocketsDiscover our wide range of power plugs, IEC, Schuko or other formats, to design your HiFi power cables.
  • IEC Connectors
    IEC Connectors
    Discover our range of IEC connectors of all sizes, for the design of your HiFi power cables.
  • Schuko Connectors
    Schuko Connectors
    Discover our range of Schuko power connectors, for the design of your HiFi power cables.
  • Various Internationals
    Various InternationalsDiscover our range of sector connectors in international formats, for the design of your HiFi power cables.
  • Schuko Inlets
    Schuko Inlets
    Discover our range of Schuko plugs, for the installation of your wall sockets.
  • IEC Inlets
    IEC Inlets
    Discover our range of IEC plugs of all sizes, for the integration of a power connector on your HiFi devices.
