SCHAFFNER FN9260 IEC C14 Base EMI / RFI Noise Filter 250V 6A with Fuse Holder
This high-performance mains filter from the Swiss manufacturer Schaffner makes it possible to filter disturbances when capacitors are no longer sufficient. This one meets strict standards.
Reference : 12716
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 18-04-2025.
Featuring a single-phase IEC C14 (male) plug, this filter accepts an input voltage of up to 250V and currents up to 6A. It will prove to be of formidable efficiency against electromagnetic disturbances (EMI) propagated by radiation or conduction.
Tension250V
Courant6A
Type de montagePanneau
Type de connecteurIEC C14
FusibleOui - 2
Taille de fusible5 x 20mm
Dimensions35 x 46 x 60.3mm
Panel drilling schema
schema perçage filtre secteur schaffner
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorIEC C14
Rated current (A)6.0
This high-performance mains filter from the Swiss manufacturer Schaffner makes it possible to filter disturbances when capacitors are no longer...
