VIBORG VF504AG Power Connector IEC C15 Pure Silver Cryo Treated Ø18mm
Viborg has further expanded its range of power connectors with the VF504Ag, a high-end IEC C15 connector that takes advantage of the best materials available to ensure perfect electrical signal transmission and enable the design of high-end power cables for your HiFi equipment. This exceptional design uses high purity silver conductors (99.998%), ensuring maximum conductivity. These conductors are also treated with a cryogenic process and placed at a temperature of -196°C for 72 hours.
Reference : 15732
249,00 €tax incl.
207,50 € tax excl.
Shipping date: 23-04-2025.
Viborg VF504Ag
Power Connector IEC C15 Silver Cryo Treated Ø18mm
Viborg VF504Ag Connecteur Secteur IEC C15 Argent Traité Cryo Ø18mm
Viborg has further expanded its range of power connectors with the VF504Ag, a high-end IEC C15 connector that takes advantage of the best materials available to ensure perfect electrical signal transmission and enable the design of high-end power cables for your HiFi equipment. This exceptional design uses high purity silver conductors (99.998%), ensuring maximum conductivity. These conductors are also treated with a cryogenic process and placed at a temperature of -196°C for 72 hours. This step allows to further improve the conductivity while ensuring a perfectly stable transmission.
The insulation of the VF504Ag uses a polycabornate Bayer-2805, powerful, resistant, and conferring a connector a unique and modern design thanks to its transparent red color. The body is then dressed with a beautiful aluminum and carbon fiber insert of the most beautiful effect.
The VF504Ag provides quick and easy assembly, with hex screws holding conductors securely and promoting excellent contact. The connector accepts cable diameters up to 18mm and conductors up to 4.8mm.
Product typePower connector
ConnectorIEC C15
ConductorsSilver (purity: 99.998%)
Insulation materialTransparent polycarbonate Bayer-2805 (made in Germany)
TreatmentCryogenic at -196°C during 72h
ShellAluminum and carbon fiber insert
Mounting typeTo screw (hex screws)
Max conductors diameterØ4.8mm (6AWG)
Acceptable cable diametersØ5~18mm
Rated voltage / current125-250VAC 10-15A
Spring materialAcier inoxydable 316
Genreal
Total dimensionsØ40 x 84mm
Max cable diameter (mm)18.0
ConnecticFemale
ConnectorIEC C15
Contacts Material (Connector)Silver
Rated current (A)15.0
Rated current (A)10.0
Viborg has further expanded its range of power connectors with the VF504Ag, a high-end IEC C15 connector that takes advantage of the best materials...
