Automatic Power Suplpy Switching Module
This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV.
Reference : 17885
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 06-10-2026.
Module de commutation d'alimentation automatique
Module de commutation automatique d'alimentation
This power supply switching module automatically switches an amplifier on and off when the module receives an audio signal with a level above 500mV. So, when the audio input detects a corresponding signal, the module's relay closes immediately and the amplifier switches on. Conversely, if no signal is received on the audio input, the relay switches again and the amplifier switches off automatically after about 90 seconds. A two-pin connector also allows integration of an external bistable switch button (not supplied) to force the amplifier to switch on.
1Audio signal input
22-pin bistable switch button connection (not included)
3220VAC Live input
4220VAC Neutral input
5220VAC Neutral output
6220VAC Live output
Trigger threshold at -36dB. Can be increased by adding a 4.7k resistor between pin 1 and pin 2 of the 2072 IC.
Product typePower supply switching module
Operating voltage220VAc
Audio control signal level> 500mV
Dimensions85*58*40mm
Mounting holes spacing77.5*52mm
Weight152g
Package1* Power supply switching module
Lugs
Screws
InputPCB Connector
OutputPCB Connector
Output voltage (V)220.0
Output current (A)NC
Input voltage (V)220.0
Power SupplyTrigger
2 reviews
Nice automatic, worth a try.
Increasing the power on time with bigger capacity (the 220 uF printed on the board, already comes with 470 uF). Go for higher values to expand the time before shut off.
Add a 4.7k resistor between pin 1 and 2 (the pins next to the point marker on the chip) to increase sensivity from -36 dB to more practical -56 dB for low listening levels.
This review has been posted for Automatic Power Suplpy Switching Module
Bon produit
Remplit parfaitement sa fonction, compact. Dommage que la modification de la tempo ne puisse se faire que par un changement de capa d'un condensateur.
