DC Power Supply Noise Reducer
FX-Audio offers with the "PETIT SUSIE" a small DC power supply filter, which effectively reduces the noise level of the power supply. It connects between an AC adapter and the device to be powered and provides the device with the cleanest possible electrical signal.
Product type | DC Power supply noise reducer |
Max voltage | 35VDC |
Max output power | 140W (35V 4A max) |
Input connector | Jack DC 5.5/2.1mm |
Output connector | Jack DC 5.5/2.1mm (Jack DC 5.5/2.5mm compatible ) |
Cable length | ~ 30cm |
Dimensions | 98 x 25.5 x 20mm |
Weight | 43g |
Input |
Output |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
