GX16 Power Cable 4N OFC for Synology NAS 1m
This cable with its GX16 connectors is perfectly adapted to power a Synology NAS with this connector. It also incorporates OFC copper conductors to ensure excellent conductivity.
Reference : 12372
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-04-2025.
Power cord for NAS Synology
GX16 type - 4N OFC - 1m
Câble GX12 Alimentation NAS Synology
GX16 format and 4N OFC Copper
Some Synology NAS models have a special power connector in GX16 format (or aviation connector). It will allow you to power your system cleanly via a quality cable.
To ensure excellent signal conductivity, this cable therefore incorporates high-purity 4N OFC copper conductors.
The following linear stabilized power supplies are available to suit this very good cable: Linear Stabilized Power Supply 12V 13A 200W for NAS
The following NAS are compatible with this cable:
Compatible NAS
Les NAS suivant sont compatibles avec ce câble :
  • Synology DS409
  • Synology DS409+
  • Synology DS410
  • Synology DS410J
  • Synology DS411
  • Synology DS411+
  • Synology DS411+II
  • Synology DS415PLAY
  • Synology DS411J
  • Synology DS412+
  • Synology DS413
  • Synology DS413J
  • Synology DS414
  • Synology DS414J
  • Synology DS415+
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
Length1m
Connectors typeGX12 4 poles male to GX16 2 poles female
Conductor material4N OFC Copper
SheathNylon
ColorBlack & Red
InputNC
OutputNC
ColorRed
MaterialCopper
Length (m)1.0
ConnecticMale & Female
ConnectorGX12
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
Câble bien fini
Câble bien réalisé. Fonctionne parfaitement avec l'alimentation LPSU200 sur un Nas Synology.
This review has been posted for GX16 Power Cable 4N OFC for Synology NAS 1m
This cable with its GX16 connectors is perfectly adapted to power a Synology NAS with this connector. It also incorporates OFC copper conductors to...
