IAN CANADA UCBALANCER Ultracapacitor Protection Module
The Ian Canada UcBalancer is a professional supercapacitor protection module specially designed to ensure that 3000F+ supercapacitors work perfectly with UcPure or other high-performance power supplies. Thanks to its high-quality design and engineering, the UcBalancer makes it possible to design power supplies with very low noise and ESR.
Reference : 17926
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 25-04-2025.
Ian Canada UcBalancer Module de protection pour supercondensateurs
The Ian Canada UcBalancer is a professional ultracapacitor protection module specially designed to ensure that 3000F+ ultracapacitors work perfectly with UcPure or other high-performance power supplies. Thanks to its high-quality design and engineering, the UcBalancer makes it possible to design power supplies with very low noise and ESR. The UcBalancer comes with a complete set of accessories, making it easy to set up high-end power supply projects, such as for clocks, streamers or DACs.
Key features:
  • Advanced 1A high constant current precision protection scheme.
  • Options for both 2.7V (default) and 3V protection/balance configuration.
  • Power MOSFET shunt circuit with PTC fuses for a double protection.
  • Has two direct ultracapacitor output connectors to get the best possible low ESR performance in continuous output mode rather than indirectly from UcPure.
  • Comes with full set of accessories for a safe and easy installation.
  • Double thickness heavy copper PCB design makes it has the lowest possible internal ESR compared to all other power supplies.
  • Fully assembled kit so there is no need for any soldering jobs during installation.
Make sure all supercapacitors are fully discharged before installation. If not, discharge them with a 10W 5Ω power resistor such as the SQP10AJB-5R (not supplied). Never short-circuit after installation.
Product typeUltracapacitors protection module
Protection voltage2.7V (default) or 3V
InputNC
OutputNC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
The Ian Canada UcBalancer is a professional supercapacitor protection module specially designed to ensure that 3000F+ supercapacitors work...
