IAN CANADA UCCONDITIONER MKII Ultra Capacitor Conditioner Board 3.3V
The UcConditioner 3.3V is a ultra capacitor signal conditioner board operating with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
Reference : 17924
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-04-2025.
Ian Canada UcConditioner MKII
Ian Canada UcConditioner MKII Conditionneur de Signaux à Supercondensateurs 3.3V
The Ian Canada UcConditioner MKII 3.3V is a ultra capacitor signal conditioner module for use with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
For audiophiles, upgrading a power supply with the UcConditioner MKII can be one of the best solutions for achieving much better sound quality.
Key features:
  • Fully ultra-low resistance MOSFET architecture.
  • Built-in automatic per-charge/charge circuits with current limitation.
  • Enable/disable conditioning is performed by monitoring ultra capacitors and DC input status.
  • All control logics are running automatically at background, no need any external control signal.
  • On-board active balancers for ultra capacitor protection.
  • LED indications for power on, power good, ultra capacitor full and conditioning.
  • Double thickness 2oz PCB copper layers especially designed for high current and ultra low ESR applications.
  • MOSFETs are controlled by optical isolators to eliminate any possible leakage current.
  • Output is 100% following the input without any delay.
  • With ON/OFF control signal output for possible requirement.
  • Works with any 3.3V power supply, plu and play, no software required.
The UcConditioner MKII is supplied without supercapacitors. These are required to operate the module and are sold separately.
Technical characteristics
Product typeSignal conditionner
Input voltage3.3V
Output voltage3.3V
Dimensions85*55.5mm
Mounting holes spacing58*49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output current (A)NC
Input voltage (V)3.3
Power SupplyPower conditioner
3 reviews
Uc330 board plus ultracaps
Extremely good.
This review has been posted for IAN CANADA UCCONDITIONER MKII Ultra Capacitor Conditioner Board 3.3V
No words!
First of all, I put a single clock on Ian Canada's dualxo board, with a very good linear feed and Ian Canada's ADM715X regulator. The result was very good: the scene was clearly going forward and upwards, more air between the instruments and more detail, the reverberations of the recording were especially noticeable.
After improving the feeding with Ian Cada Lifepo4 and UCconditioner MKII the change has been even more spectacular, highlighting that there is still more clarity in the recordings, and my system is already very transparent, but what stands out the most is the considerable increase in bass. I have a system with coxial speakers and ripol subwoofer, the theory says that I should not have a seismic bass, typical of closed boxes, but surprisingly and inexplicably it has appeared with the change of power. I have to say that my system is very good and I have some amazing speaker cables, I don't know if the effect on more modest systems can be just as good.
nice quality and works fine
already bought several ian canada products and just like this one it really adds something and a very good quality.
use this in combination ian canada PurePi to 3.3 volt input FifiPi MA.
 (3)
The UcConditioner 3.3V is a ultra capacitor signal conditioner board operating with a 3.3V power...
