IAN CANADA UCCONDITIONER MKII Ultra Capacitor Conditioner Board 5V
The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum current delivery.
Reference : 17923
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-04-2025.
Ian Canada UcConditioner MKII
Ian Canada UcConditioner MKII Conditionneur de Signaux à Supercondensateurs 5V
The Ian Canada UcConditioner MKII 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
For audiophiles, upgrading a power supply with the UcConditioner MKII can be one of the best solutions for achieving much better sound quality.
Key features:
  • Fully ultra-low resistance MOSFET architecture.
  • Built-in automatic per-charge/charge circuits with current limitation.
  • Enable/disable conditioning is performed by monitoring ultra capacitors and DC input status.
  • All control logics are running automatically at background, no need any external control signal.
  • On-board active balancers for ultra capacitor protection.
  • LED indications for power on, power good, ultra capacitor full and conditioning.
  • Double thickness 2oz PCB copper layers especially designed for high current and ultra low ESR applications.
  • MOSFETs are controlled by optical isolators to eliminate any possible leakage current.
  • Output is 100% following the input without any delay.
  • With ON/OFF control signal output for possible requirement.
  • Works with any 5V power supply, plu and play, no software required.
The UcConditioner MKII is supplied without supercapacitors. These are required to operate the module and are sold separately.
Technical characteristics
Product typeSignal conditionner
Input voltage5V
Output voltage5V
Dimensions85*55.5mm
Mounting holes spacing58*49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower conditioner
The UcConditioner 5V is a ultra capacitor signal conditioner board operating with a 5V power supply....
