IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V
The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
Reference : 18925
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 22-04-2025.
Ian Canada UcConditioner Pro Ultra Capacitor Conditioner Board 5V
For audiophiles, upgrading a power supply with the UcConditioner Pro can be one of the best solutions for achieving much better sound quality.
Key features:
  • Fully ultra-low resistance MOSFET architecture.
  • Built-in automatic per-charge/charge circuits with current limitation.
  • Enable/disable conditioning is performed by monitoring ultra capacitors and DC input status.
  • All control logics are running automatically at background, no need any external control signal.
  • On-board active balancers for ultra capacitor protection.
  • LED indications for power on, power good, ultra capacitor full and conditioning.
  • Double thickness 2oz PCB copper layers especially designed for high current and ultra low ESR applications.
  • MOSFETs are controlled by optical isolators to eliminate any possible leakage current.
  • Output is 100% following the input without any delay.
  • With ON/OFF control signal output for possible requirement.
  • Works with any 5V power supply, plu and play, no software required.
Ian Canada UcConditioner PRO Conditionneur de Signaux à Supercondensateurs 5V
Technical characteristics
Product typeSignal conditionner
Input voltage5V
Output voltage5V
Dimensions (with capacitors)85 x 55.5 x 75mm
Mounting holes spacing58*49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)5.0
Power SupplyPower conditioner
4 reviews
Upgrade Alim Linear PI pour 5V du FIFO PI Q7 II
Petit retour d'expérience sur ces supercondos de chez Ian Canada. En effet, dans mes autres post sur mon streamer audio à base de produits Ian Canada je ne suis pas déçu de cet upgrade de supercondos en sortie de l'alimentation 5V régulée Linéar PI de chez Ian Canada, tout ça pour alimenter le reclocker FIFO PI Q7 II !! Même si l'apport en qualité n'est pas aussi flagrant, il y a tout de même un petit gap avec ce qui suit :
- Une amélioration de la scène sonore (plus d'espace)
- Une dynamique plus grande
- Une séparation des instruments et surtout des voix
- Des fins de notes plus silencieuses
- Des voix plus naturelles et très charnelles
- Des graves très tendus et très propres
- des micro détails très lointains auparavant qui se détachent nettement
- Un son très analogique sans les effets du numérique et sans les inconvénients de l'analogique
A noter que dans cet upgrade j'ai aussi changer les Horloges de mon reclocker FIFO PI Q7 II par des SC Pure, Il est donc difficile de dire si c'est l'horloge qui l'emporte sur cet upgrade ou l'ajout des supercondos.
Dans tous les cas après lecture de bien des avis sur les forums concernant les DACs, les Reclokers, les alimentations ou les horloges et après avoir vérifié par moi même en upgradant petit à petit mon streamer audio (cela m'a pris 2 ans et ce n'est pas fini) à base de Raspberry 4 avec des produits de chez Ian Canada. Il y a à chaque fois une amélioration de la qualité sonore du système qui est très nette à condition d'avoir des enceintes capables de révéler ces différences. Pour ma part je suis en Haut Rendement, bi-amplifé avec en amont un filtre actif Najda tweaké muni de sorties analogiques épaulé par des Ampli OP de compétition de chez Sparkos Labs (les plus haut de gamme, du pure class A). Pour les HP Altec 414 Z (30 cm) , chambre de compression TAD 2001 (membrane Béryllium d'origine) + Pavillon DIY (tournage CNC).
Pour finir beaucoup de passionnés se chiffonnent sur les forums de discussion pour afficher leurs préférence bec et ongle concernant tel ou tel Dac. Après avoir écumé beaucoup d'info à ce sujet j'ai retenu ce qui suit chaque dac a sa signature sonore avec nos préférences personnelles. Cependant même un dac qui au premier abord ne nous a pas plus peu se révéler redoutable après avoir changé les alims, les horloges, le reclocker, etc... C'est ce que j'ai pu vérifier en construisant mon propre système, voilà pour mon avis perso. Si cela peut servir pour prendre des décisions dans des réalisations futures, c'est plutôt cool.
Jean-François.
This review has been posted for IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V
Génial
Super upgrade pour mon RPI qui sert de Host Diretta...
Avant j'avais une alim Allo Shanti. Là c'est le jour et la nuit : je pense me faire un streamer complet en Ian canada...
C
pure battery voltage
just as good battery thanks to the Ultra Capacitor
5 volts
equally good farad super 3 or ifi powerelite
unexpected!
This power supply is a great upgrade. Also if you have the previous version. Which i have. Thus I was very sceptical about any noticeable upgrade. But this is a big one!
The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve...
