IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 3.3V
The Ian Canada UcConditioner Pro 3.3V is a ultra capacitor signal conditioner module for use with a 3.3V power supply. It will significantly improve the quality of your power supply by reducing both internal ESR and noise levels, while optimizing stability and maximum delivered current.
Reference : 19013
145,00 €tax incl.
120,83 € tax excl.
Shipping date: 22-04-2025.
Ian Canada UcConditioner Pro Ultra Capacitor Conditioner Board 3.3V
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 3.3V : Front view
For audiophiles, upgrading a power supply with the UcConditioner Pro can be one of the best solutions for achieving much better sound quality.
Key features :
  • Fully ultra-low resistance MOSFET architecture.
  • Built-in automatic per-charge/charge circuits with current limitation.
  • Enable/disable conditioning is performed by monitoring ultra capacitors and DC input status.
  • All control logics are running automatically at background, no need any external control signal.
  • On-board active balancers for ultra capacitor protection.
  • LED indications for power on, power good, ultra capacitor full and conditioning.
  • Double thickness 2oz PCB copper layers especially designed for high current and ultra low ESR applications.
  • MOSFETs are controlled by optical isolators to eliminate any possible leakage current.
  • Output is 100% following the input without any delay.
  • With ON/OFF control signal output for possible requirement.
  • Works with any 3.3V power supply, plu and play, no software required.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 3.3V : Dimensions
Product typeSignal conditionner
Input voltage3.3V
Output voltage3.3V
Dimensions (with capacitors)85 x 55.5 x 75mm
Mounting holes spacing58 x 49mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)3.3
Output current (A)NC
Input voltage (V)3.3
Power SupplyPower conditioner
The Ian Canada UcConditioner Pro 3.3V is a ultra capacitor signal conditioner module for use with a 3.3V power supply. It will significantly...
