This LHY Audio 3.3V 1.5A low-noise voltage regulator module uses the recommended integration method of the Analog Devices LT3042 + PNP high-end regulator. This provides near-zero noise voltage regulation and a high output current of 1.5A. It can therefore deliver a pure power supply for DACs, high-precision measuring instruments, noise-sensitive RF applications and much more, with a ripple of just 0.6µVrms. What's more, the module accepts two input modes: DC or AC.
Product type | Voltage regulator module |
Output voltage | 3.3V |
Output current | 1.5A |
Voltage regulator chip | LT3042 |
RMS Noise | 0.8µVrms (10Hz to 100kHz) |
PSRR | 79dB @ 1MHz |
Bandwidth | 1MHz |
Dropout voltage | 350mV |
Supply voltage | 3.3-20V DC 3-13V AC |
Dimensions | 39 x 82 x 29mm |
