Here is a 30cm power cable that can be used for example to power a T-amp, a DAC, a SqueezeBox on battery or with a DIY power supply.
On one side you will find a female connector 5.5 / 2.1mm, and on the other 2 wire (Phase and neutral) to be soldered on your DIY application.
Features:
Input | NC |
Output | NC |
Length (m) | 0.3 |
Shielding | No |
Section (mm²) | N/A |
Connector | Bare wires |
Connector | Jack DC |
Output voltage (V) | NC |
Output current (A) | NC |
Input voltage (V) | N/A |
Power Supply | NC |
Conductors material (Cable) | Copper Alloy |
Conductors Plating (Cable) | None |
