Power Cable Jack DC 5.5 / 2.1mm Female to bare wire 30cm (Pair)
This is a 30cm power cable that can be used for example to power a T-amp, a DAC, a SqueezeBox on battery or with a DIY power supply.
Reference : 16730
1,40 €tax incl.
1,17 € tax excl.
Shipping date: 22-04-2025.
Here is a 30cm power cable that can be used for example to power a T-amp, a DAC, a SqueezeBox on battery or with a DIY power supply.
On one side you will find a female connector 5.5 / 2.1mm, and on the other 2 wire (Phase and neutral) to be soldered on your DIY application.
Features:
  • Length: 30cm
  • Maximum current: 2A
  • External Diameter of Connector: 5.5mm
  • Internal Diameter of Connector: 2.1mm
  • Cables: 2 x 2.5mm diameter Ø
  • Color: Black and red
  • Sold in pairs
InputNC
OutputNC
Length (m)0.3
ShieldingNo
Section (mm²)N/A
ConnectorJack DC
ConnectorBare wires
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
Conductors material (Cable)Copper Alloy
