Cable d'excellente facture,tres bien construit
Power Cable Jack DC 5.5/2.5mm to GX16 OFC 4N Copper 1.5m
This quality power cable has a 5.5/2.5mm DC jack connector and a GX16 connector (or aviation connector) 2 female poles. The conductors of this cable are made of 4N OFC Copper to ensure excellent conductivity of the electrical signal. A red and black nylon sheath covers the cable and protects it, ensuring very good flexibility and increased resistance to mechanical stresses (twisting, pulling, etc.).
This cable is compatible with our power supplies LPSU200 and LPSU100.
Please note that there is no standard for polarities on GX16 connectors. The - and + polarities may be inverted, depending on the manufacturer, and may not be compatible with certain devices. Using a non-compatible cable can result in the destruction of your equipment.
This cable is not compatible with the following Audiophonics linear power supplies (different polarity) :
AUDIOPHONICS Double Regulated Linear Power Supply 5V / 12V 30W T-Amp V-DAC2 LT1085
AUDIOPHONICS Double Regulated Linear Power Supply USB 2x 5V 1.5A 7.5W LT1086
Product type | Power cable |
Length | 1.5m |
Connectors type | Jack DC 5.5/2.5mm to female 2 poles GX16 |
Conductor material | 4N OFC Copper |
Conductors cross section | 15AWG / 1.65mm² |
Sheath | Nylon |
Color | Black and red |
Length (m) |
Shielding |
Section (mm²) |
Connector |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
Conductors material (Cable) |
Conductors Plating (Cable) |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
