Power Cable Jack DC 7.4 / 5mm Male to bare wire 1.2mm
This 1.2m jack power cable can for example be used to power a laptop, an amplifier or an external hard drive with a DIY power supply.
Reference : 17437
2,90 €tax incl.
2,42 € tax excl.
Last items in stock !
Shipping date: 22-04-2025.
Jack DC POWER CABLE
DC 7.4 / 5mm male to bare wires 1.2m
Réducteur plaqué or pour câble de haut parleur 2mm
This 1.2m DC jack power cable can be used to power a laptop, amplifier or external hard drive with a DIY power supply.
On one side you will find a 7.4/5mm male Jack connector, and on the other 3 bare wires 1.2mm to be soldered or connected to your DIY application.
Connectors correspondence
xxx
1External surface -> black cable
2Internal surface -> White cable
3Central pin -> blue cable
Technical caracteritics
Lenght1.2m
Maximum current4A
Jack Eexternal diameter7.4mm
Jack internal diameter5mm
Conductors diameter3x 1.2mm diameter
Conductors cross-section3x AWG18 (0.82mm²)
ConditioningSold by unit
InputNC
Length (m)1.2
ShieldingNo
Section (mm²)0.823
ConnectorBare wires
ConnectorJack DC
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyNC
Conductors material (Cable)N/A
