Speaker Protection
This double (±) power supply module can accommodate 2 electrolytic capacitors 63V 10000µF of 35mm diameter (sold separately) for filtering. The module integrates a 25A diode bridge and a 2x5A Omron relay. A NEC UPC1237 protection chip will also ensure a high level of security for your loudspeakers. Mounting is done simply by means of screw terminals.
Filter capacitors are sold separately.
Product type | Power supply module / Speaker protection |
Compatible capacitors (sold separately) | 2x 63V 10000µF Ø35mm 10mm contact spacing |
Rectifier bridge | 25A |
Relay | Omron 2x5A |
Protection chip | NEC UPC1237 |
Mounting | To screw |
Dimensions | 103 x 62mm |
Input |
Output |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
