Voltage Display Voltmeter with Green LED 5-60VDC Ø22mm
This voltmeter will allow you to monitor the voltage of a device. Its green LED display is easy to read. The voltmeter accepts voltages from 5VDC to 60VDC. Its connection is simplified by a screwing system.
4.0 / 5
Reference : 17587
3,90 €tax incl.
3,25 € tax excl.
Voltmeter
Afficheur de tension voltmètre à LED verte 60-500VAC
Product typeVoltmeter
ModelAD16-22DVM
Voltage range5-60VDC
LED ColorGreen
Precision± 5V
Cutout diameterØ 22mm
Connection systemTo screw
Total dimensions50.5 x 28.4mm
Input
  • Screw terminals
Output
  • NC
Color
  • Green
Output voltage (V)
  • NC
Output current (A)
  • NC
Input voltage (V)
  • N/A
Power Supply
  • NC
Bonjour, les vis des deux contacts ont été serrées exagérément par le robot ou l'outil final, il faut de la poigne pour les desserrer avant de mettre les deux fils, et cela fait peur.
This review has been posted for Voltage Display Voltmeter with Green LED 5-60VDC Ø22mm
This voltmeter will allow you to monitor the voltage of a device. Its green LED display is easy to read. The voltmeter accepts...
