WONDOM PS-BC12311 Package Functional cables for module BCPB3 / BCPB4 / BCPB6
This cable kit contains all the necessary connectivity to use all the features of your Wondom battery managers.
Reference : 14115
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 23-04-2025.
WONDOM PS-BC12311
This cable kit contains all the connections required to use all the features of your battery Wondom managers.
They include relevant cables to connect your amplifier modules (JAB) and output modules to easily power your devices with a strong batteryt
The kit has conventional IC connectors for associations with other Wondom modules as well as IC connectors to bare wires for purely DIY applications and even other accessories to expand capacity.
A PH-4 pin discharge cable is used to directly connect a device (usually a Wondom device) to a BCPB3 (J2-J20) or BCPB4 (J4/J18) battery management module.
A coding device is present.
Same as before, but the output is done on bare wires to power devices that do not have the PH connectivity found on Wondom devices.
Level indicator and switch control.
Wondom PS-BC12311 Package câbles pour BCPB3 / BCPB4
2-pin MicroFit discharge cable for powering other devices via the BCPB4 (J13).
4-pin FastFit discharge cable for powering other devices via the BCPB4 (J17).
2-pin MiniFit discharge cable for powering other devices via the BCPB3 (J16).
Power LED Indicator Cable: BCPB3 (J4) / BCPB4 (J7).
On-load status indicator diode.
Cigarette lighter adapter to charge your batteries anywhere.
USB male to DC 5.5/2.5mm jack cable. Ideal for powering your devices with a DC jack input exclusively.
Extension cable to integrate another interface.
vérifier l'utilité de ce kit avant de commander
les cartes de gestions de charge de batteries wondom sont livrées avec ce kit de cable donc inutile de commander ce kit si vous avez commandé un WONDOM PS-BC12112
This review has been posted for WONDOM PS-BC12311 Package Functional cables for module BCPB3 / BCPB4 / BCPB6
