Power Supply Module 15VA +/-17V DC Non regulated
This power supply module has an input voltage of 220V AC on IEC C8 connector, and a non regulated output voltage of +/- 17V DC on screw terminal block or 3.96mm 3 pin connector.
Reference : 14980
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 18-04-2025.
Power Supply Module
+/-17V DC
Module d'alimentation 6V AC
This power supply module has an input voltage of 220V AC on IEC C8 connector,and a non regulated output voltage of +/- 17V DC on screw terminal block or 3.96mm 3 pin connector.
The module embeds a 15VA 12V AC sealed transformer, as well as four 2200µF filter capacitors, ensuring a Filtered DC supply. The assembly is mounted on a transparent acrylic plate.
Product typePower supply
Input voltage220V AC
Input connectorIEC C8
Output voltage+/-17V DC
OutputScrew terminal
3.96mm 3 pins connector (3 pins to bare wires cable included)
Ripple< 10mV
Temperature range-40°C - +85°C
Dimensions105 x 60 x 61mm
Weight500g
InputIEC C8
OutputScrew terminals
Output voltage (V)17.0
Output current (A)NC
Input voltage (V)220.0
Power SupplyLinear
This power supply module has an input voltage of 220V AC on IEC C8 connector, and a non regulated output voltage of +/- 17V DC on screw terminal...
