Power Supply Module 15VA +/-9V DC Non regulated
This power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of +/-9V DC on screw terminal block or 3.96mm 3 pin connector.
Reference : 14979
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 18-04-2025.
NON REGULATED Power Supply Module
+/-9V DC
Module d'alimentation 6V AC
This power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of +/-9V DC on screw terminal block or 3.96mm 3 pin connector. The module embeds a 15VA 6V AC sealed transformer, as well as four 2200µF filter capacitors, ensuring a clean and stable electrical signal. The assembly is mounted on a transparent acrylic plate.
Product typePower supply
Input voltage220V AC
Input connectorIEC C8
Output voltage+/-9V DC
OutputScrew terminal
3.96mm 3 pins connector (3 pins to bare wires cable included)
Ripple< 10mV
Temperature range-40°C - +85°C
Dimensions105 x 60 x 61mm
Weight500g
InputIEC C8
OutputScrew terminals
Output voltage (V)9.0
Output current (A)NC
Input voltage (V)220.0
Power SupplyLinear
This power supply module has an input voltage of 220V AC on IEC C8 connector, and an output voltage of +/-9V DC on screw terminal block or 3.96mm 3...
