WONDOM PS-BC12211 USB power supply / charging connector for BCPB4
Reference : 14112
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 24-04-2025.
DC / DC battery cradle Wondom
Wondom BCPB / DC
This small module is primarily designed to operate with a Wondom battery cradle. It provides a standardized connection to use your charging solutions over USB powered devices.
Two female USB ports can charge one or two devices simultaneously. These ports comply with BC1.2 standard and are compatible with most devices designed for USB charging with a current of up to 2.1A.
It also includes a DC input jack to handle the charging of accumulators installed on the battery-craddle module. The latter is also connected to an LED serving as a charging indicator.
Used in conjunction with Wondom Batteries Manager it is possible to enjoy a very high capacity battery for various applications, ranging from simple high performance mobile battery, to a supply for your systems based Raspberry Pi.
Supply (input)8VDC (min) 12VDC (typ) 24VDC (max)
StandardBC1.2
idle current@VIN = 12V: 25-50mA
Voltage USB Output@VIN = 4.75VDC (Min) 5.1VDC (Typ) 5.25VDC (Max)
USB outputs Current@VUSB = 5.1V: 2.1A
Maximum Operating Temperature50 ° C
Dimensions6.09 x 5.33 x 0.38 cm
Weight48g
InputJack DC 5.5/2.1mm
OutputUSB
Output voltage (V)5.0
Output current (A)NC
Input voltage (V)12.0
Input voltage (V)20.0
Input voltage (V)10.0
Input voltage (V)15.0
Input voltage (V)24.0
Input voltage (V)8.0
Power SupplyNC
