As already mentioned in some forum there is no voltage drop (!?) Adjusting the blue spindle trimmer does not change anything. Ripple comes down
from PSU: 2,5 mV
to CM: 0,5 mV
(@12,6 V, no load, Multimeter).
Any Idea?
Capacitance Multiplier allows the simulation of a greater capacitance effect on a continuous power supply stage. The point is to lower the ripple noise to a HiFi quality level.
This specific design filters the noise from a SMPS PSU until reaching almost non-significative level of noise (
This the final element to improve audio quality on a SBC / Sparky while using such devices for HiFi, Multiroom, DAC, amp...
Main effects are :
- Improved sound stage
- Lower distorsion on medium / high frequencies
- Improved dynamics on low signals.
Caution : this is not a voltage regulator. Tension must always be higher than the noise on the power line.
Specifications | ||
Input Voltage | Min : 6V Max : 30V | |
Voltage selection per potentiometer | 0-3V | |
Voltage stability | 0.5V | |
Noise rejection | >70dB | |
Input connector | Jack DC 7.3/3.0mm | |
Dimensions | 66 x 63 x 51mm | |
Weight | 130g |
Package content | |
Molex adapter 4 pins to Jack DC 6.5/3.0mm | x1 |
Spacers are NOT included |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Axel A.
