IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V supercapacitor power supply and a second isolated 3.3V LifePO4 battery rail. Thanks to the use of spring contacts, it is very easy to install a Raspberry Pi or other audio HAT on top of the PurePi, without the need for an additional power supply connector.
Reference : 18200
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 27-12-2024.
Ian Canada PurePi II
The PurePi is from a functional point of view equivalent to a ConditionerPi 5V associated with a LifePO4Mini 3.3V.
Version II
This new version of the PUREPI offers a number of significant improvements.
Version II improvements and new features :
  • [New feature] SYNC charging function added. This allows the battery to be re-loaded when the music stops, prolonging usage time while avoiding voltage drops and triggering the protection mode. Perfect for long listening sessions.
  • [New feature] Also works for Pi free applications.
  • [Upgrade] Support USB-C PD (power delivery) protocol. This enables the use of high-speed USB-C cables.
  • [Upgrade] No longer locks SD card, ON/OFF control connector has been moved.
Key features:
  • 5V supercapacitor power supply with two 100F-2.7V supercapacitors pre-installed. ESR less than 10mΩ.
  • Isolated 3.3V power supply on LifePO4 battery, with pre-installed battery cradle for two 18650 cells. ESR below 6mΩ.
  • Gold-plated spring contacts to power a Raspberry Pi directly via the GPIO, without adding a connector.
  • Works as a stand for a complete audio project. Spikes can be installed, as well as rubber rings, to limit vibrations.
  • Only a 5V 2.5A power supply required as input, via USB-C.
  • Integrated ON/OFF button. Can be deported to have an external switch.
  • ON/OFF control signal for integration into a multi-power supply system as a master ON/OFF control.
  • Integrated protection system to prevent battery wear and maintain an adequate electrical signal.
  • Ultra-low noise and high dynamic range passive power supply.
  • Ultra low ESR MOSFETs controlled by optical isolators to eliminate current leakage.
Product typePower supply module for Raspberry Pi
Input voltage5V 2.5A
Output voltageUltracapacitor power supply: 5V
Batteries power supply: 3.3V
Dimensions141*108mm
Mouting holes spacing127*94mm
InputScrew terminals
OutputPCB Connector
IAN CANADA PUREPI
Incredible power system for Raspberry PI and for ES9038 + FIFO Q7 II. Allows you to obtain a very clean power supply. Great work at a low cost. I am very satisfied
This review has been posted for IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality....
