IAN CANADA SHIELDPI PRO MKIII Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi
Ian Canada's ShieldPi Pro MKIII is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO extender/multiplier. The IR remote control function can also be implemented if the module is used with a MonitorPi (sold separately).
Reference : 19591
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 24-04-2025.
IAN CANADA SHIELDPI PRO MKIII : 3/4 view
The ShieldPi Pro card is suitable for all Raspberry Pi applications to reduce both EMI and power supply noise. Installation is extremely simple using the GPIO connector.
Key features :
  • Single point zero current grounding shield plate to eliminate EMI noise from the Raspberry Pi.
  • 5V power supply filter networks with high bandwidth and very low ESR, covering a wide frequency range.
    ESR : 2mΩ @ 200kHz, 0.3mΩ @ 2MHz, 1mΩ @ 20MHz, 4mΩ @ 200MHz
  • pins GPIO extension.
  • 40 pins GPIO multiplier (AUX GPIO).
  • Has an ON/OFF button for Raspberry Pi and a connector for external button.
  • Possibility to implement the IR remote control function of the Raspberry Pi when integrated with MonitorPi (sold separately).
  • Reduces both EMI and power supply noise.
  • Improves the performance of Raspberry Pi based systems.
Ian Canada ShieldPi Pro: New features in MKIII version
  • Built-in ultra-low noise 3.3V/500mA power supply, capable of powering FifoPi, DAC or other devices without using additional 3.3V power supply
  • Optical receiver makes IR remote controller working for Raspberry Pi
  • 5V input/output connector can power a RaspberryPi directly from GPIO with bypassing the USB power input.
  • Optimized PCB layout
Product typeEMI shielding and power supply filter board for Raspberry Pi
InputGPIO
OutputGPIO
Weight50g
Dimensions65 x 89 x 25mm
Mounting hole spacing46 x 55mm
Package1x Ian Canada ShieldPi Pro MKIII
1x Power cable
4x Spacers
Ian Canada's ShieldPi Pro MKIII is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply...
