IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi
Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter, ON/OFF control button and GPIO extender/multiplier. The IR remote control function can also be implemented if the module is used with a MonitorPi (sold separately).
Reference : 16965
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 27-12-2024.
Ian Canada ShieldPi Pro
Module multifonction Blindage EMI / Filtre d'alimentation pour Raspberry Pi
The ShieldPi Pro card is suitable for all Raspberry Pi applications to reduce both EMI and power supply noise. Installation is extremely simple using the GPIO connector.
Key features:
  • Single point zero current grounding shield plate to eliminate EMI noise from the Raspberry Pi.
  • 5V power supply filter networks with high bandwidth and very low ESR, covering a wide frequency range.
    ESR : 2mΩ @ 200kHz, 0.3mΩ @ 2MHz, 1mΩ @ 20MHz, 4mΩ @ 200MHz
  • 40 pins GPIO extension.
  • 40 pins GPIO multiplier (AUX GPIO).
  • Has an ON/OFF button for Raspberry Pi and a connector for external button.
  • Possibility to implement the IR remote control function of the Raspberry Pi when integrated with MonitorPi (sold separately).
  • Reduces both EMI and power supply noise.
  • Improves the performance of Raspberry Pi based systems.
Product typeEMI shielding and power supply filter board for Raspberry Pi
InputGPIO
OutputGPIO
InputGPIO
OutputGPIO
2 reviews
IAN CANADA SHIELD PRO
It works very well and is certainly a clear improvement of the power supply of the raspberry PI as well as being an excellent shield for EMI. I am very satisfied.
Alessandro Catalano
This review has been posted for IAN CANADA SHIELDPI PRO Multifunction Board EMI Shielding / Power Supply Filter for Raspberry Pi
Excellent product
At this price this is a really excellent product, the effect on the sound is clearly perceptible. I put it on my Raspberry 3B between it and a R2R DAC and the result leads to an undeniable clarity improvement.
Ian Canada's ShieldPi Pro is not only a universal EMI shielding module for Raspberry Pi, but also a high performance power supply filter,...
