Switching power supply, 5 A, with switchable output voltage
Characteristics :
High power for small dimensions and low weight.
Current values vary depending on the selected output voltage. Refer to the table.
Technical data Power supply | |||
![]() | Input Voltage | ![]() | 100-240 V~ / 50-60 Hz / 60 VA |
![]() | Output voltage | ![]() | 6 / 7,5/ 9/12 / 13.5 / 15 V direct current |
![]() | Load / Output Current | ![]() | 5/5/5/5 / 3.8 / 3.8 A |
![]() | Charging time | ![]() | - |
![]() | Holding load | ![]() | - |
![]() | Reactivity | ![]() | - |
![]() | Operating temperature | ![]() | 0-40 ° C |
![]() | dimensions | ![]() | 70 x 37 x 140 mm |
![]() | Weight | ![]() | 480 g |
Output voltage (V) | 13.5 |
Output voltage (V) | 7.5 |
Output voltage (V) | 9.0 |
Output voltage (V) | 6.0 |
Output voltage (V) | 15.0 |
Output voltage (V) | 12.0 |
