ALLO AC/DC Switching Power Adapter 5V 3A DC + Micro USB
4.6 / 5
Reference : 11638
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 15-04-2025.
Here is an AC adapter Power supply 100-240V AC to 5V 3A DC in 2.1mm jack or Micro USB. Ideal for replacing your faulty or disconnected battery or equivalent charger. Can also be used as a power supply for your DIY projects and fixtures, which often require precise voltages.
This AC adapter is ideal forrecall Kali from ALLO thanks to its Jack end.
It is also suitable for plugging into Micro USB Single Board Computer Sparky, where the Raspberry Pi 3.
Characteristics :
  • Switching power supply compatible with a mains voltage of 100 to 240V AC (50-60Hz)
  • Output in: 5V - 3A (3000mA) DC
  • Output Jack Diameter of Output: External 5.5mm / Internal 2.1mm
  • Cable length 1.5m
  • Includes a USB to Micro USB Adapter
  • Includes USA and UK plug adapters
  • CE compliant
  • Color: black
Output voltage (V)5.0
5 reviews
Useful
Good balance between price and quality. Delivery really fast, customer service very good.
This review has been posted for ALLO AC/DC Switching Power Adapter 5V 3A DC + Micro USB
fait le job
Dommage que cette alimentation n'ait un design one spot. On n'est pas toujours tout seul sur une multiprise
Great little PSU
Works well with the Rpi 3B+ and Allo DigiOne, no audible jitter or noise (don't have the equipment to measure this technically, so going by hearing).
Doesn't get hot, and has a convenient long cord.
Rien à redire
L'alim fait le boulot. Utilisée avec un Pi3 A+, un écran 7" officiel pi et un DAC AUDIOPHONICS I-Sabre LTE DAC ES9023, je n'ai plus de problème de "low voltage".
Dommage cependant de devoir jeter les adaptateurs pour les autres pays... déchets inutiles.
Suffisant
Il alimente un kali, un raspberry et un tda 1387. Pas de petite flêche indiquant une puissance insuffisante. Pour le son je ne sais , c'est la seule alimentation dont je dispose.
