IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 5V 5A
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device with a clean and stable power supply.
Reference : 15100
299,00 €tax incl.
249,17 € tax excl.
iFi Audio iPower Elite
iFi Audio iPower Elite Adaptateur Secteur à Annulation de Bruit Active 5V 5A
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis:
  • A high-performance 60W adaptive multimode controller optimized for high efficiency, low standby power and noiseless design.
  • Frequency shuffling technique to achieve excellent performance against EMI interference.
  • 400% increase in the power supply capacity of the adaptive multimode controller.
  • Oversized power MOSFET.
  • Low leakage transformer.
  • Background noise less than 1µV.
  • Noise cancellation technology.
  • Aluminum frame with integrated heat sink.
Active Noise Cancellation 2
Active Noise Cancellation 2 technology actively suppresses incoming noise, using similar operation to noise-cancelling headphones. A signal identical to the incoming electrical noise is generated with an inverted phase, in order to perform this noise cancellation.
This method is particularly effective in eliminating noise in the low and medium frequencies, while passive filtering deals with interference in the high frequencies. This intelligent combination is more effective than simple passive filtering.
Product typeAC adapter
Input voltage100-240VAC (50-60Hz / 1.5A)
Output voltage / current5V DC 5A
Output connectorJack DC 5.5/2.1mm
Noise floor< 1µV
Dimensions148 x 55 x 50mm
Weight550g
Package1x iFi Audio iPower Elite
1x Jack 5.5/2.5mm to USB-C adapter
1x Jack 5.5/2.5mm to Micro USB adapter
1x Reverse polarity Jack DC adapter
1x Power cable
Output voltage (V)
  • 5.0
Exceptionnel RQPerformance
Deja utilisateur de la version 12v sur le ifi zen stream. Les resultat sur le BonnN8 sont du meme niveaux. Ali a decoupage de haute techno et qualité, elle vaut des ali lineaire hifi de deux fois le prix avec un silence incroyable. La musique vivante naturel et precise.. Je recommande fortement. Le cable ali 5v est esclave mais d exelente qualité. Pour les plus exigeant vous pouvez y monter une prise elecaudio cuivre telure pl or 5,5/2.1 pizr remplacer celle d origine..
This review has been posted for IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 5V 5A
The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device...
