IFI AUDIO IPOWER MK2 Audio Power Supply Low Noise 15V 1.2A
The iFi Audio iPower MK2 power adapter delivers an extremely clean and stable electrical signal to your audio devices. This new version of the iPower features improved components and thicker cabling for better noise suppression at the input and output. This makes it 10 times quieter than most audiophile power supplies.
Reference : 15501
79,90 €tax incl.
66,58 € tax excl.
iFi Audio iPower MK2 Adaptateur Secteur / Alimentation Audio Faible Bruit 15V 1.2A
The iFi Audio iPower MK2 power adapter delivers an extremely clean and stable electrical signal to your audio devices. This new version of the iPower features improved components and thicker cabling for better noise suppression at the input and output. This makes it 10 times quieter than most audiophile power supplies. The iPower MK2 also comes with an adapter that allows you to reverse the polarity of the DC jack connector if needed.
Active Noise Cancellation II
The iPower MK2 takes advantage of the Active Noise Cancellation II technology, which actively suppresses the input noise. To do this, it generates a signal identical to the electrical noise but in phase opposition.
Product type100-240VAC
Output voltage15V 1.2A
Output connecteurJack DC 3.5/1.35mm
Jack DC 4.0/1.7mm
Jack DC 4.8/1.7mm
Jack DC 5.5/2.1mm
Jack DC 5.5/2.5mm
Reverse polarity adapter (White)
Noise floor~1µV
Dimensions82 x 43 x 43mm
Weight165g
Cable diameterØ8mm
Output voltage (V)15.0
The iFi Audio iPower MK2 power adapter delivers an extremely clean and stable electrical signal to your audio devices. This new version of the...
