This LDNIO power adapter features three USB-A and USB-C ports and up to 140W of power. GaN3.0 technology makes it compatible with a wide range of fast charging protocols, including USB-PD, USB-PPS and USB-QC. This means it can be used with a wide range of devices, including laptops, smartphones, Nintendo Switch and tablets. With this fast charger, for example, you can fully recharge your phone in half an hour, or your laptop in just under 2 hours.
This AC adapter also incorporates a number of protection features to protect any devices connected to it: protection against overvoltage, overheating, overload, short-circuit, undervoltage problems, etc. It can also be used to supply power to certain Hi-Fi devices with a USB power port, such as the BERRYBAK HEV250. This AC adapter delivers voltages suitable for a wide range of applications:
Product type | GaN power adapter |
Connector | 3x USB-A 3x USB-C |
Input voltage | 100-240V 50-60HZ 2.5A (MAX) |
Max. power | 140W |
Output voltages | USB-C : 5V/3A 9V/3A 12V/3A 15V/3A 20V/5A 100W (MAX) USB-A : 4.5V/5A 5V/4.5A 5V/3A 9V/3A 12V/2.5A 20V/1.5A 30W (MAX) |
Fast charging protocols | PD3.0 / QC4.0 / PD2.0 / PPS / QC4+ / QC3.0 / QC2.0 / SCP / FCP |
Dimensions | 34mm x 112mm x 90mm |
Color | Black |
Weight | 270g |
Package | 1x GaN power adapter USB-C / USB-A 1x USB-C to USB-C cable 50cm 1x EU plug 1x UK plug 1x US plug 1x 1.5m extension cable |
Output voltage (V) | 5.0 |
Output voltage (V) | 20.0 |
Output voltage (V) | 9.0 |
Output voltage (V) | 12.0 |
Output voltage (V) | 4.5 |
Output voltage (V) | 15.0 |
