MEAN WELL AC/DC Switching Power Adapter 100-240V AC to 9V 2A DC
This AC adapter AC 100-240V (50 / 60Hz, 0.7A) to 9V 2A DC is ideal for replacing a similar HS or defective model.
Reference : 12628
16,90 €tax incl.
14,08 € tax excl.
Power adapter Mean Well 7.5V 2.9A
This AC adapter AC 100-240V (50 / 60Hz, 0.7A) to 9V 2A DC is ideal for replacing a similar HS or defective model. It can also be used to power DIY projects requiring precise tensions and amps. The unit incorporates anti-overload, anti-surge and anti-short circuit protection. The power supply does not require an IEC cable and its output connector is in the DC 5.5 / 2.1mm format.
TECHNICAL CHARACTERISTICS
  • Input: 100-240V AC, 50 / 60Hz, 0.7A
  • Output: 9V DC, 2A, 18W Max
  • Output Connector: Jack DC 5.5 / 2.1mm
  • Power Outlet Type: EU
  • Length: 1.2m
  • Weight: 200g
  • Block dimensions: 79 x 54 x 33mm
Adaptateur secteur alimentation Mean Well 7.5V 2.9A
Output voltage (V)9.0
