MEAN WELL AC/DC Switching Power Adapter 100-240V AC to 5V 4A DC
Reference : 14624
17,90 €tax incl.
14,92 € tax excl.
Mean Well Power adapter DC 5V 4A
This IEC C8 power adapter incorporates a high performance switching power supply and can deliver a direct voltage of 5 Volts with an intensity of 4 Amps.
It is equipped with overload protection as well as overvoltage protection.
Ideal for cleanly powering your audio circuits such as DAC or dematerialized streaming solutions requiring a voltage of 5V with a substantial power reserve.
This device needs a power cable (IEC C7) that is sold separately.
Power Supply TypeSwitching mode power supply
Input voltage85 - 264 V AC
Output voltage5V DC
Max output intensity4A
Input connectorIEC C8
Output connectorJack DC 5.5 / 2.1mm
Efficiency81.5%
ProtectionsOverload
Overvoltage
Polarization Center pin is positive
Cable length (output)1m
Temperature-30...70°C
Weight202g
Dimensions79x54x33mm
Output voltage (V)5.0
3 reviews
Super alim pour DAC
Utilisée pour alimenter un DAC Topping E30 II de façon optimale, semble être un excellent rapport qualité/prix.
Pas grand chose à ajouter, si ce n'est qu'il faut prévoir un cordon secteur.
This review has been posted for MEAN WELL AC/DC Switching Power Adapter 100-240V AC to 5V 4A DC
better than hypex smps
thats is enough to say
meanwell is meanwell
the smps brand choosen for nelson pass's pass aca class a diy amp.
Not casualty, the only one smps can make analog audio device sounds almost as good as with linear psu
