Motorized Volume Control Board 50K
This handy volume control module is equipped with a 50K motorized potentiometer and an IR receiver LED. This last one is associated with an IR remote control allowing to control the volume level of the module simply and remotely.
Reference : 15006
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 24-01-2025.
Motorized 50K
Module contrôle de volume motorisé 50K
Product typeMotorized volume control module
PotentiometerALPS 907M-50KAX2
Curve typeLogarithmic
Potentiometer shaft diameterØ6mm
Potentiometer shaft typeD Shaft
Input1x Analog input on solder pads
Output1x Analog output on solder pads
IR Reception LED
Remote control(Piles AAA 1.5V sold separately) (Random color black / white)
Power supply6-9V AC or 6-12V DC (sold separately)
Dimensions (without potentiometer shaft)62 x 46 x 27mm
InputSolder pad
OutputSolder pad
Channel2 (Stereo)
4 reviews
Doet zoals beloofd werkt perfect.
Goed product simpel te installeren (misschien zou het iets sneller mogen werken)
This review has been posted for Motorized Volume Control Board 50K
Everything working as it should and board have output to switch ON or OFF some aditional board with relay on it - of course with remote controll :) Very usable. Motor works very slow but fast enough for me. With on Board LED Diode we see when you press ON/OFF Button on remote power is ON - LED IS SHINING and when you Controll Volume up or down LED IS BLINKING. Very satisfied ... Bravo
Excellent
Easy to use,compact,logarithmic pot,works great. Fast delivery.
tres bien
livraison rapide dans mon cas super produit fait parfaitement le boulot je recommande ce produit
This handy volume control module is equipped with a 50K motorized potentiometer and an IR receiver LED. This last one is associated with an IR...
