Phono Preamplifier Board Low Noise OPA JRC5532
This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF each and two WIMA 1µF coupling capacitors, for a clean signal and a rich and precise sound reproduction.
3.5 / 5
Reference : 15390
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 30-01-2025.
Phono preamplifier Board
Module préamplificateur phono faible bruit AOP JRC5532
This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V filtering capacitors of 4700µF each and two WIMA 1µF coupling capacitors, for a clean signal and a rich and precise sound reproduction. The resistors used have a high accuracy of ±1% for a very good SNR. The power supply of the module is made in 12VAC.
Product typePhono preamplifier board
Input / OutputOn solder pad
Power supply12V AC (power supply not included)
Dimensions110 x 75 x 30mm
Mouting holes spacing102 x 70mm
InputSolder pad
OutputSolder pad
Channel2 (Stereo)
2 reviews
Idéal pour rénover une vielle platine
Acheté pour "électronifier" ma vielle platine Thorens et choisi pour l'intégration de sa propre alimentation, ce module a pu être logé sous le chassis et a donné entière satisfaction. J'en ai profité pour ajouter une embase secteur IEC et des embases RCA, le tout disponible sur le site audiophonics. Un petit bémol : la position des entrées / sorties RCA qui ne facilite pas la soudure des câbles de modulation.
Merci encore audiophonics pour la rapidité des réponses à mes demandes de précisions.
This review has been posted for Phono Preamplifier Board Low Noise OPA JRC5532
Trop sensible
Sature très rapidement. Faible gain
This phono preamplifier module benefits from a nice design, using two JRC5532 AOPs mounted on DIP8. It is also equipped with two Nover 35V...
