Bon produit, notamment la qualité du métal constitutif du potentiomètre.
Pour information et parce que c'est indiqué nulle part, le bouton se démonte en tirant franchement dessus.
The TinySine TSA1000 is a digital volume controller with integrated Bluetooth management for convenient use. This one will be able to associate without problem with a Bluetooth amplifier TinySine TSA7499B. It will thus allow you to control the volume via its rotary knob.
Digital volume control module
The TinySine TSA1000 is an asymmetric digital volume controller with integrated Bluetooth management for convenient use. This one will be able to associate without problem with a Bluetooth amplifier TinySine TSA7499B. It will thus allow you to control the volume via its rotary knob.
The module therefore has an unbalanced audio input and output in the form of JST connectors, as well as a Bluetooth control port. The output signal will increase or decrease using the Rotary encoder. The Bluetooth Pa control will act the same way on the signal, for remote control.
TSA7499 Amplifier with TSA1000 Volume Controller
Port name | Pin name | Direction | Description |
Audio In | GND | - | |
R | Analogic input | Audio input | |
L | Analogic input | Audio input | |
Audio Out | GND | - | |
R | Analogic output | Audio output, connect to amplifier board | |
L | Analogic output | Audio output, connect to amplifier board | |
Bluetooth control | 5V | - | |
GND | - | ||
INC | Digital output | Bluetooth volume + | |
DEC | Digital output | Bluetooth volume - | |
SEL | Digital input | Select Bluetooth / Asymétrique : 0 = Singled-Ended 1 = Bluetooth |
Volume control | Bluetooth et single-ended |
Power supply | 5V DC |
Dimensions | 50 x 38mm |
Package | 1x TinySine TSA1000 1x 5 Pins female XH cable 1x 3 Pins female XH cable 1x Male / Female 3 pins XH cable |
Average votes 4.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Guillaume F.
