This TinySine TSA1110 module will allow you to control the volume of your audio system remotely directly via your smartphone via Bluetooth or by using the potentiometer on the back of the module.
DIY Bluetooth Volume Control Module Android / iOS Compatible
Caution to use this item, your amplifier must have capacitors on its input. |
This TinySine TSA1110 module will allow you to control the volume of your audio system remotely directly via your smartphone via Bluetooth or by using the potentiometer on the back of the module. For remote control, Tinysine proposes a dedicated application allowing to act on the sound volume thanks to a digital potentiometer and this up to a distance of 30m. The internal potentiometer value will change automatically when you change the volume via the application. It is available under Android and iOS.
The TAS1110 is very simple to install. It has 3 ports at the rear: an audio input, an audio output and a 5V DC Jack power plug (not supplied).
Note : The TSA1110 is not a Bluetooth receiver. It simply allows remote volume control via this technology.
The TSA1110 also exists in a version with a box.
Max bluetooth distance | 30m |
Bluetooth standard | 4.0 |
Compatibility | Android V2.2 or more iPhone 4S or more recent |
Power supply | 12V DC via Jack DC 5.5/2.5mm (not included) |
Dimensions | 96 x 41 x 20mm |
